07-20-2012 05:33 AM
Hi all,
I'm having trouble saving a Power Spectral Density waveform to a TDMS file because the method I'm using is losing the x-axis (frequency) scaling. The only way I can get it to save is extracting the magnitude from the waveform and saving that in the TDMS file. This loses all the frequency information.
Does anyone know how I can save the PSD information in a TDMS file or failing that, any type of file?
Thank you,
Solved! Go to Solution.
07-23-2012 03:52 AM
I've downloaded and took a look at the "Data Calculations TDMS 4.vi", however I'm not sure which part in the VI you have problem with. Would you please offer more informatin?
07-23-2012 09:10 AM
Hi deppSu,
If you look at the jpeg of the front panel, the frequency of the 'Power Spectral Density 2' graph, you can see that the frequency component is centred around 12 Hz instead of 0.4 Hz where it should be. This is what is being saved in the TDMS file and it's incorrect.
Thank you,
07-25-2012 12:41 AM - edited 07-25-2012 12:47 AM
As my understanding, you are trying to log the PSD to "Power Spectral Density" channel, but you do it wrong with double array. TDMS write don't accept cluster as input, but accept waveform. I have updated the VI and the PSD in TDMS file viewed as
07-25-2012 08:13 AM
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
