01-30-2015 02:53 AM - edited 01-30-2015 03:03 AM
maybe someone can help me. My problem is that i don't know, how can i connect 3 nibbles (any 4bit) values (ticks (decimal), not binär values) to a 12bit value in decimal unit? Here a short example: 1st nibble: 3 (decimal, 4bit); 2st nibble: 10 (decimal, 4bit) and the third nibble: 8 (decimal, 4bit). Actually, this three nibbles should be one data-value in decimal unit. How is the relation? How can i combine the single nibbles to one value? For a Example for a SENT-signal look at the attachments.
Thanks for help and best regards,
Sebastian
Solved! Go to Solution.
01-30-2015 06:40 AM
Not sure want you exactly want. Maybe something like this ?
Kees
02-01-2015 07:53 AM
thanks for your fast response. Unfortunally, i can not open your VI because i only have the Labview 2013 version. Maybe you can convert the VI?
Best regards
Sebastian
02-02-2015 01:37 AM
In LV 2013
Kees
02-02-2015 02:57 AM
Thank you. This is the solution.
Best regards
Sebastian
04-21-2015 01:53 AM
could you please provide nibble.vi also for LV2012?
thank you in advance
Elena
04-22-2015 01:39 AM
And in LV 2012
04-22-2015 01:41 AM
Thank you very much
best regards,
Elena
