Signal Conditioning
SCXI_Reset gives a timeout error (-10800) occasionally
I have two chassis's controlled by two seperate DAQ boards. PXI 6052E controls chassis one (SCXI 1001 with six 1102c's) and PXI 6031E controls chassis two (SCXI 1000 with three 1102's). Chassis Two is the one that causes the timeout error.
(2,911 Views)
Greetings,
The -10800 timeout error is an odd error to be returned from the SCXI_Reset() function. What do you mean by occasionally? How often does the error get returned? Are there special circumstances in your test that might be related to this error? When you receive this error are you still able to communicate with your DAQ board and/or the SCXI chassis?
If you change the order in which the SCXI_Reset is called, such that you attempt to reset chassis 1 before chassis 2, does this make a difference?
Justin Britten
(2,911 Views)
