Signal Conditioning
SCXI Detection problem
I'am running NI-DAQ 6.9.2 on a Win2000Pro system, with an PCI-6024-E board and an SCXI1000 chassis, When I configure my devices in MAX and let MAX scan for the devices in my SCXI chassis, he returns an SCXI-1120, instead, an SCXI-1100 is mounted. When I manually install an SCXI-1100 module, he returns an error on testing the chassis.
My channels are working with the manual installed SCXI-110 module, but in programs (exe) i've got problems. I'm running programs on Run-Time 5 and there i've got the problem when i'm reading OB channels and SCXI channels at the same time, he returns 0.00 for al the SCXI channels at that time. Reading SCXI channels, or OB channels seperatly is no problem..
Is there somebody who has got any idea????
PS- these programs ar
e working fine on the same combination, instead using Win98. There no problem with the programs, and no problem with the SCXI detection.
Thanks.......
(2,848 Views)
You could try upgrading your NI-DAQ. If you don't want to go to 7, there was a 6.9.3 version that may work. Newer drivers may have solved the problem.
-Warren
(2,848 Views)
