08-13-2011 12:16 AM
I have a DAQ card PCI 6036E. I want to use Signal conditioner SCXI 1520 for my measurements. What are the accesories required for the installation of SCXI 1520.
Priyank
08-14-2011 11:45 PM
Hi Priyankbit,
You would need to have SCXI chassis with SCXI 1349 with 68-68 Pin E-Series DAQ cable (SH68-68-EP) to plug in the SCXI 1520 and connected to the PCI 6036E. You may need to have the connector block to SCXI 1520 to connect your sensors to the SCXI 1520.
In detail, you may want to look at SCXI page.
http://sine.ni.com/nips/cds/view/p/lang/en/nid/1604
I hope that this helps
06-19-2012 05:29 AM
I am using SCXI 1520 with PCI 6036e DAQ with SCXI 1000 and 1314 in between. Can I get counter output (pulse generation) using this configuration? If yes, please let me know how?
Priyank
07-21-2014 12:45 PM
Hi evereybody
Iam fairly beginner with Labview 2012 to create a gain-settings of SCXI 1520 VI.
I would like configurate gain from scxi 1520 analog inputs with labwiew and find in user manual a tool for this.you can see the picture.
But this VI isnt executable,because i have labview 2012 with newest daq driver.
This tool works with old daq driver. New daqmx cannt find this files.
AI Parameter
AI Config
AI Read
can any person help me?
Thanks.
