Signal Conditioning
SCXI 1321: Do I pull out the nulling resistors...?
Do I pull out the nulling resistors to disable the nulling circuit? The manual that came with the 1321 says to pull them out, but the online documentation says nothing about them.
(2,633 Views)
Greetings,
Placing the enable/disable jumpers (W1-W4) in position D (disable) will disable the nulling circuit for each channel. You should be able to leave the nulling resistors in place.
Good luck with your application.
Spencer S.
(2,633 Views)
