03-08-2015 09:25 PM
I am seeking assistance with wiring the SCC FT01 feed-through module with a SC 2345 to measure pressure changes.
Which pin on the feed-through module accepts the connection with the analog input of the shaft encoder?
If you require more details, I'd be happy to provide them. Thanks in advance for the help!
-Carolyn 🙂
03-09-2015 01:55 PM
Hello, you can look at the information that you are seeking in these links
http://www.ni.com/pdf/manuals/371075b.pdf
http://www.ni.com/pdf/manuals/373743d.pdf
There you can find the device's manuals and see how the wiring should be done.
I hope this helps!
