Would it be possible to modify SC-2040 so one can connect mA signal to the input instead of V signal? Anyone has tried to do it? Any comment welcomed. Thanks.
Check out the link below. This should work with the SC-2040. I hope this helps.
Measuring Current Using the Analog Input of a DAQ Board? http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/82508cd693197ea68625629700677b70?OpenDocument
Thanks toddd, Sure it does help. We can see that SCXI boards have space for precision resistor. However, I am not sure if I can do the same with SC-2040. Circuit-wise it should work, yet my concern is physical location.
