06-11-2015 12:57 AM
06-11-2015 04:53 PM
Hi Ahmed_WT,
Do you see the same behavior when you use the Bridge-Continuous Input.vi example in the NI Example finder?
If you are not familiar with the NI Example Finder you can access it by going to the Help tab in LabVIEW and selecting Find Examples.
The specific example that I'm referring to can be found in Hardware Input and Output>>DAQmx>>Analog Input>>Bridge-Continous Input.vi.
Regards
06-15-2015 04:39 AM
Dear Thank you for your help. the problem was because scaling.
