I would appreciate some adivce on deciding what temperature sensor to use. The range of the application is limited to 32 -42c. It will be used to measure temperature of the body at various sites. It should be very small ( around 0.014inches) The most important aspect of the sensor should be that it should have a resoltuion of 0.05 or even better. I am planning to use the PCI 4351 for measurements, so as far as the electronics is concerned I am sure that resolution will not be a problem. However, when I contacted several thermistor manufacturers I was told that the resolution only depends on the electronics. I am not sure at all if that is correct. So what parameters of the sensor itself should I be inquiring about?. What is the rel
ationship between accuracy of the sensor, sensitivity and resolution ? HOw does one define the resoltion of the thermistor?.Does greater sensitivity of the sensor mean better resoltuion? Does the size of the thermistor affect its sensitivity/resoltuion?
If I decide to use a thermocouple, then what parameters should i be looking at to get the required resolution?
