Signal Conditioning
Need For Help With SCXI-1102 - Reading individuals Channels
Can I read individuals channels separated with commas, using SCXI-1102 ? If I read using this syntax "1:5", everything is O.K. I want to read channels 4,8,15,22 using the SCXI-1102 Labview example and I got -10007 Error Code.
what i'm doing wrong ?
(2,960 Views)
Here is a link which should explain this for you, but basically you must scan channels sequentially with the SCXI-1102.
Scanning Multiple, Non-sequential Channels from SCXI Modules
(2,960 Views)
Thanks For your answer. It helps me a lot.
thanks again...
(2,960 Views)
