Hey John,
There is actually a shipping example that in LabVIEW 5.0.1 that you can use with the SCXI-1161. You can find the example by selecting Search Examples and then going to Data Acquisition>>SCXI and there you will find a VI entitled 'SCXI-116x Digital Ouput VI' that you can use with the SCXI-1161.
Certain digital lines of the SCXI-1200 are used to communicate with and control the SCXI modules but the SCXI-1161 doesn't use any additional digital lines. The document linked below describes which digital lines of the SCXI-1200 are used for the communication.
Digital Ports that are reserved on the SCXI-1200 when used with an SCXI module.
http://digital.ni.com/public.nsf/websearch/5FED65F7CBD1C86E852563FD00649C08?OpenDocument
T
odd D.
NI Applications Engineer
