The SCC-PWR01 (power options 1) converts the +5VDC from your DAQ board to the +/-15VDC that the SCC modules require. I assume when you are talking about 9-28VDC or 10.5-45VDC for your pressure transducers you are referring to the excitation that they require. This has nothing to do with the power option for the SC-2345. Power options 1 - 3 just supply power to the SC-2345 and the SCC modules. What you need is excitation for your transducer.
I would not recommend just tapping into the 15VDC that is made available to the modules since you may put too much of a current/power draw on the SC-2345 and/or your DAQ board since that is where the power is ultimately coming from. I would recommend external excitation for your transducers.
Justin Bri
tten
