NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
Firas3001
Accepted Solution
How can i design square signal which having a positive and negative values equal to each other and separated from each other by controlled time or distance
How can i design square signal which having a positive and negative values equal to each other and separated from each other by controlled time or distance, As it is shown in the figure below. and enter this signal in a daq.
Active Participant
Henrik_Volkers
Re: How can i design square signal which having a positive and negative values equal to each other and separated from each other by controlled time or distance
[ Edited ]
By the time you spend for the nice diadram you might have done the vi :smileywink:
Your DAQ like to have a waveform (array of values and dt ak 1/samplerate)
If you set the samplerate you know the array length , create a array of zeros, and set the values of both amplitudes ...
Since I don't want to wire others homework :smileywink: here are some pictures
And there are some drawbacks is room for improvement in my solution, just think of rounding errors ... and what might happen if the arrays get bigger ....
Spoiler
Greetings from Germany
Henrik
LV since v3.1
Member
Firas3001
Thank you very much Henrik Volkers...I appreciate you help...
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
