05-18-2014 08:03 AM
Hi all,
I want to design filter to implement on FPGA with a mentioned parameters in subject but when i am starting to design it on matlab fdatool, it gives very high order filter result, and when i decrease or set by myself upto 10 order its impulse response is not good as i want.
I am using high speed ADC with 250MSPS.
Any idea will be highly appreciable.
Umair
Solved! Go to Solution.
05-19-2014 04:54 AM
Hi umaair_65,
If the order of the selected filter is very high, because you need a high attenuation or a specific inpulse response, than it is the result of the design parameters.
I think you can only
- Change the type of filter (IIR instead of FIR)
- Change the parameters (cutoff frequency, ...)
- Use multiple filters instead of one filter
Regards, Stephan
05-19-2014 05:25 AM
Hi Stephan,
If i go with second option of changing the place of cutoff frequency like 5MHz then may be it will give better response but what do you think it will create a problem when i will implement this on FPGA?
Secondly if i go with the same second number solution for high pass filter, i have already analysed in Matlab a high pass filter with 50 order and it gives better impulse response on FDATOOL but again my question is,it will affect the signal of between BP filter range??
Umair
05-19-2014 06:24 AM
Hi Umair,
you can theoretically designe any filter you want on a FPGA. If you can implement the filter on a give FPGA-Target is another story.
There are usally some limitations on a FPGA, which you have to take into account:
- Number of FlipFLops, LUT, ...
- Maximum loop rate
- Number of available multipliers
It is almost not possible to tell you, if you can implement your filter on a given FPGA-Taregt. The only way to get the proper answer is to try it. A filter with order=50 could be really large and maybee doesn't fit on the FPGA or doesnt meet the loop rate which you need.
I don't use the FDATOOL, so I can't give you an answer to your second question.
Stephan
05-19-2014 06:53 AM
Thanks Stephan,
Umair
