Hi there.
I�ve been having problems with a SCXI-1000. I am using a SCXI-1000, with a SCXI-1200 (controlling the chassis), a SCXI-1120 and a SCXI-1163. I developed a program in LabVIEW to take temperature readings (through the SCXI-1120) and send digital signal through the digital outputs of the SCXI-1163. The SCXI-1200 is only used to control the chassis.
The problem occurs after some time running (which is variable, it can be one day, two days or a few hours), when that infamous blue Windows screen is displayed with the following message (translated from portuguese) :
" Windows
An Exception 0E occurred at 0028:C980C906 in VxD NIDAQK(01) + 00007906. It was called from 0028:C23DA3D0 in VxD NIPALK(01) + 00026330. It may be possible to continue normally. ..."
Hitting any key the program continues normally, and at a random time later, the problem repeats.
Let me trace the history of this development.
I was having a lot of problem using the SCXI. After some time, the data acquisition always died with a timeout error message.
I then tried to disable every energy saving feature on both BIOS and Windows. Then the program was working fine for a few weeks, until the problem of the timeout started again.
Then I tried to reset the SCXI-1200 everytime a timeout was detected. Again, it worked for a few weeks, but then that blue screen described above started to appear. When this blue screen problem appeared, I was using LabVIEW 5.1 with NI-DAQ 6.9.1f28. After some unsuccessful attempts, I decided to install LabVIEW Base 6.1 and NI-DAQ 6.9.2 over the previous installation. Again, it didn�t worked. Finally, I tried to change the computer. I installed on this new computer LabVIEW 6.1 and NI-DAQ 6.9.2, and the same blue screen problem still happens.
I am in a hurry to finish a project and this problems won�t let me do it.
I just don�t know what else I can try. I am sending attached a stripped version of my program (only with the DAQ part and a few variables). The main control routine is the daq_control.vi. There are the workarounds I mentioned to get the best reliability from the system.
PS : The first problems I described were successfully fixed disabling the Energy saving and reset the SCXI-1200 whenever necessary. Only the blue screen problem I wasn�t abel to fix yet.
