04-24-2014 10:48 AM
Does anyone have an expample for averaging temperature arrays from an 1102. I have a way of doing it but it would be difficult and I was hoping that there would be a better solution than pulling each TC from an array and doing a running average on those. Since I have 62 TCs that would take a lot of doing.
Solved! Go to Solution.
04-29-2014 01:57 PM
teslac,
I don't have an example but this shouldnt be overly complex. You can start by using channel expansion (or a DAQ assistant) to acquire all your TC data in one task. Then use a filter express VI set for smoothing with a rectangular window. If the acquisition VI and smoothing filter are both in the same loop you will get nicely averaged data.
04-30-2014 08:11 AM
RE: I have not used filter express only statistic and math funtions to do things like this in the past which can be laborious with interlaced and multiplexed signals. I was hoping there was an easier way and this sounds like the ticket.
