I am trying to record information from three accelerometers that is connected to an SCB-68 board. The SCB-68 is connected to a PCI-6062E DAQ card on my notebook. Each of the accelerometers have 4 leads coming out of the cable. (+/- power and +/- output)
I have connected the +/- output leads to pin 33 and pin 66, respectively. Should I also jumper pin 66 to pin 32 (AIGND)? I am using an external 5V excitation voltage for the accelerometers.
Right now, I get erroneous information when checking the inputs on MAX. I am expecting a small signal voltage but I am reading signals from +10V to -1V, not uniform.
From the information I have given so far, am I connecting everything right?
