We are running a SCXI-1161 in a SCXI1001 chassis controlles by a 4021 card. When i tried to test some cabling i noticed the following behaviour: Started the SFP. Closed Channel 0 with Functional Control ->LowLevelAccess->RelayControl. Did the same with Channel 1. When i run Functional Control ->LowLevelAccess->GetRelayPosition it says "closed" for both Channels. But my Ohmmeter says that Channel 0 was opened , when I closed Channel 1. Fortunately the "Test panel" in MAX works as expected Installed Software : NI Switch 2.00.49156 NI DAQ MX 7.0.0f0 MAX 3.0.0.3014
