05-12-2014 12:20 PM
05-12-2014 01:36 PM
It really depends on what characteristics of the signals you need to compare.
Even though the signals have the same frequency, unless they are both generated simultaneously by the same source, there will be frequency errors.
How much phase shift can occur? How much noise is present? How small a difference must be detected (amplitude, frequency, phase, distortion, ...) to declare the test signal bad?
Lynn
05-13-2014 07:26 AM
Thanks for the fast response.
I am not sure about how much noise we have. And I do not think we have to worry about the phase shift.
As for what classify as a failure I may need some more time to make that judgment since I am waiting on new hardware to determine what classified UUT (unit under test) as failure. When it come to this I am basically a novice so I wanted to see what methods was out there and starts preparing code.
I figure there were several common techniques I could apply to waveform I have. The waveform I have measure start and figure of test. My test has two parts. I am mostly concern with the first part. When I get the new hardware I will be able just get waveform on first part.
Attached are images of the waveforms I am currently getting. Good result. Bad result. And worse result.
05-13-2014 02:36 PM
I see one obvious difference between good and bad results: the slope of the portion starting at 1.4 V. If that is consistently related to the failure mechanism of your devices, it would be easy to test. Find the minimum. Go 1.5 to 2 seconds after the minimum and check the voltage there. Good is less than 1.6 V, bad is greater than 1.6 V!
If this is the only type of failure you do not need to compare waveforms, only two points.
Lynn
05-14-2014 09:10 AM - edited 05-14-2014 09:14 AM
Sorry, I forgot the last type that need to be test. There is a 4th type, which is harder to determine visual. The fourth type is why I wanted to use a method (or methods) to compare the two signals.
With the new hardware I will be able to focus on first part better. But just in case, I still cannot tell the different I will need a method to determine how the waveforms are different.
*FYI: the waveforms I measured show the start (first part) & the finish of my test (2nd part).
I was wondering if smoothing out my current data will show the different from the good and the sort of bad waveform data visually. I found these YouTube series about smoothing below.
My main goals is to use my LabVIEW program to compare two waveforms.
Youtube series links
series 1 : https://www.youtube.com/watch?v=AxlyqR-vGe0
series 2 : https://www.youtube.com/watch?v=E3CuIQ9V73Y
series 3 : https://www.youtube.com/watch?v=jq1wPp0o-Fg
series 4 : https://www.youtube.com/watch?v=JWYliXDiDsM
05-14-2014 12:38 PM
Before you work on methods to spearate the good from the bad, you need to carefully and explicitly define what is good and what is bad. What is it about the 4th type which distinguishes it from a good part? Just because you cannot see a difference does not mean that you cannot measure it, but you must decide what you need to measure.
Is it possible that the device is bad but generates a perfectly good waveform under these conditions? For example the waveform might be fine but the device temperture is too high. In that case an addtional measurement - the device temperature - would be required.
I doubt that smoothing will be of any value on the waveforms you have posted.
Lynn
05-15-2014 09:14 AM - edited 05-15-2014 09:16 AM
There are many ways that have been used for this kind stuff:
have a look at the waveform monitoring vis:
Limit testing
or
pulse durations, rise/fall times and positions, histogram , integral, DFT
one way is to ask yourself how you decide, but you can extract all the above indicators (and XX more) and try to train a neural network ...
05-19-2014 07:18 AM
Thanks for all the suggestions. Once I smart running the test with the newer hardware, I will post this question again (with more details). That will take couple weeks.
08-14-2018 08:26 AM
Hi I am working with the same task, as I am very new to the LabVIEW I dont have much idea about signal waveform comparison. Can you please help me how you did it, what technique did you used.
Thanks & Regards
Rihan Malik
