This library provides enhanced functionality for handling INI configuration files. Instead of using the Config File VIs included in LabVIEW (palette -> File I/O -> Configuration File VIs), use the like-named top-level VIs in Enhanced Config.llb, or access them via the Config Main folder in Enhanced Config.lvlib. Note that this library is not yet complete: The functions Remove Key.vi and Remove Section.vi are not provided. Also, the function Not A Config Data Refnum.vi is not provided, however the version in vi.lib will work with these new functions.
You can have this for free (and it's worth every penny!), but I offer no guarantee that it all works as it should.
Use it at your own risk.
There are 2 enhancements over the native LabVIEW Configuration File VIs.
1. Support for Unicode INI Configuration Files
The following file formats are supported:
ASCII, UTF-16 Big Endian, and UTF-16 Little Endian. (You can create Unicode files with Notepad).
Open Config Data.vi outputs an enum that tells you the file format.
Also, when using it to create a new config.ini, you can specify the format.
When sending strings to the functions (Section Name, Key Name, Key Value), you may use either ASCII, or UTF-16 BE, or UTF-16 LE, regardless of the format of the file. Of course if you have a Unicode config.ini file and you have Section and/or Key names using codepoints > 255, then you would have to use UTF-16 BE or UTF-16 LE to specify the Section/Key. However if the Section/Key names your Unicode config.ini file only use codepoints < 256, then you can specify them with ASCII.
Strings that are output from the functions (Section Names, Key Names, Key Values) will be either ASCII, or UTF-16 BE, or UTF-16 LE depending on the format of the config.ini file. You can determine the format of an ASCII, or UTF-16 BE, or UTF-16 LE string using Unicode.llb\Remove Unicode BOM.vi. (Note however that there's no way to distinguish between a Unicode string without a BOM (Byte Order Mark) and an ASCII string.
Since creating Unicode block-diagram constants can be a bit tricky, I've included some utilities to help you. See Utilities.llb.
Note: In the documentation and label names of VIs:
2. Improved Support for Multi-line Keys
This makes them more human readable in the .ini files:
Originally, multi-line keys had to be like:
KeyName = "Line 1\0ALine 2\0A\Line 3"
Now they can be like:
KeyName = "
Line 1
Line 2
Line 3
To have a multi-line key in the new format, a newline must immediately follow the opening quote.
