Reference Design Content
Microsoft Visual C++ Client Reference Example for Simple Messaging (STM)
The attached file contains a client implementation of STM in Microsoft Visual Studio 2010 and an example of its use. This example does not implement a server for STM connections, although much of the code can be re-used for a server implementation.
Requirements
The Visual C++ code was written in Microsoft Visual Studio 2010.  Much of the code can be converted to other MS VC++ versions with minimal effort.
Example Description
The attached example contains the following:
VC++ STM Client Folder
This folder contains the VC++ STM implementation as well as an example of its use.
The following files are significant:
STMSession.h and STMSession.cpp
These files implement the STMSession Class, which implements the main STM communication.  This class is directly used to connect to the server, disconnect from the server, and send messages.  The class also provides messages via a STMDispatch object.
STMDispatch.h and STMDispatch.cpp
These files implement the STMDispatch Class, which provides notifications to the application when STM communication events occur.  To define handlers for these messages, inherit from this class and overload the associated functions.  This class allows you to receive notification of a successful connection, the loss of a connection, the receipt of meta data, the receipt of any data on the STM socket, the receipt of an STM message, a successfully transmitted message and/or a connection error.  To register for notifications, you should call the STMSession:: SetDispatch function and pass an object of a class that inherits from STMDispatch.
STMConvert.h and STMConvert.cpp
These files provide a number of functions which help you to encode and decode data into a format acceptable by LabVIEW.  This is called flattening and unflattening.  Note that not all possible data types are implemented. If you need a data type that isn't available, use the provided functions as a guide and the refer to Flattened Data for the data format.
STMExample.h, STMExample.cpp, STMExampleDlg.h, and STMExampleDlg.cpp
These files implement an example of using STMSession and STMDispatch to communicate with an STM server.
LV Server Folder
This folder contains a LabVIEW server designed to communicate with the C++ example client.  The example is a CompactRIO system that acts as a server for multiple STM clients.  The cRIO streams analog waveforms from a cRIO module, scans digital inputs, updates digital outputs, and transfers a cluster of system status information.  This example is a good test for the C++ implementation as it uses multiple data types, arrays, and clusters in its STM messages.
Feedback
Please submit your feedback and questions on this example in the STM discussion forum. General product support questions should be directed to NI Technical Support.
authored by
Christian L, CLA
Principal Systems Engineer - Partner and Ecosystem Development - National Instruments
Any attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed
application or system, or for use in hazardous environments. You assume all risks for use of the Code,
and use of the Code is subject to the Sample Code License.
Contributors
