Reference Design Content
Inter-cRIO Deterministic Communication
This design example shows a method for passing fast deterministic data between two cRIO backplanes, making use of a single trigger line on an NI-9469 Chassis Synchronization Module. The example passes data continuously at just under 300 kB/s on a single trigger line.
Source and Description: https://decibel.ni.com/content/docs/DOC-41768
authored by
Christian L, CLA
Principal Systems Engineer - Partner and Ecosystem Development - National Instruments
Any attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed application or system, or for
use in hazardous environments. You assume all risks for use of the Code, and use of the Code is subject to the Sample Code License.
Contributors
