Reference Design Content
Embedded High Speed Monitoring and Datalogging Reference Application
by Active Participant Christian_L ‎08-24-2010 09:38 AM - edited ‎03-02-2017 09:53 AM
This reference design provides a CompactRIO application with focus on embedded high speed data acquisition, monitoring and data logging.
The data acquisition code in LabVIEW FPGA must be customized for the C Series modules that are used in the application. The data must be streamed to disk and important features must be  extracted and logged to file. The files that are generated need to be moved off the controller and the local hard drive must be monitored to prevent it from filling up. Finally the application must be outfitted with headless configuration and communication abilities.
Code and Documentation: http://www.ni.com/example/31388/en/
Discussion Forum: http://forums.ni.com/t5/Sound-Vibration-Applications/cRIO-Reference-Design-for-Vibration-Data-Logger...
Requirements
  • LabVIEW, LabVIEW Real-Time, and LabVIEW FPGA 2015
  • NI-RIO 15.0 or later
  • NI CompactRIO Waveform Reference Library (v4.1 or later)
  • NI Software Watchdog (v1.0 or later)
  • NI GXML (v1.41 or later)
  • NI STM (v2.1 or later)
Contributors
