Reference Design Content
Asynchronous Multi-File TDMS Data Logger
This is a library of functions for an asynchronous TDMS logger. It allows you to dynamically run an asynchronous thread for data logging with additional functionality of separating the data into multiple files based on size or date and time. It also implements functions to delete old files that would normally overflow your hard drive.
Source and Description: https://decibel.ni.com/content/docs/DOC-39366
authored by
Christian L, CLA
Principal Systems Engineer - Partner and Ecosystem Development - National Instruments
Any attached Code is provided As Is. It has not been tested or validated as a product, for use in a deployed
application or system, or for use in hazardous environments. You assume all risks for use of the Code,
and use of the Code is subject to the Sample Code License.
Contributors
