07-07-2008 05:13 PM
07-10-2008 09:42 AM
07-11-2008 09:26 AM
07-18-2008 10:54 AM
01-14-2009 04:39 AM
this design does not make use of FPGA bitfiles. My question is, would this also work with FPGA code that is embedded in an rtexe? In theory I don't see why it would not work, but am having trouble making it work correctly.
Any information on the subject would be appreciated.
01-14-2009 05:04 PM
Yes, in theory it should work also for any FPGA VIs and bitstreams that are included as part of the RT EXE. Please include a simple example showing the problem or include more detailed information about what is and what is not working.
As long as the master system (source of the image) is working as expected and the target system uses the same HW (same FPGA), this process is designed to copy over the exact image from one system to another.
01-27-2009 02:58 AM
Hi Christian,
thanks for the information. I still need to do some tests to try and figure out exactly what isn't working right since the ones I have done so far have been somewhat inconclusive. It's good to know though that it should work with FPGA bit-files.
It seems that it doesn't always run the swapping process correctly, but I will do some more tests before I'm able to give more detailed information on what is not working.
05-03-2012 05:11 AM
Can it work on sbRIO 9606?
05-07-2012 02:25 PM
This reference design should work on the sbRIO-9606 as well, although we have not specifically tested it on that device.
02-13-2013 09:45 AM
The new Reference Design for Plugin and Image Deployment to a CompactRIO using a Memory Device is now available.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
