08-24-2007 12:38 PM
09-17-2007 03:34 AM
09-18-2007 03:08 PM - edited 09-18-2007 03:08 PM
Message Edited by Doug S on 09-18-2007 03:15 PM
08-28-2015 02:57 PM
I have run into an issue with Multiple client implimentation in LV2013. server works well with one client which only sends data to server. but when a second client connects (only reading ) the loop on the server seems to slows down. watching timestamps on probe, it looks like 25 seconds per received message. when second client is stopped the loop slowly recovers as all the messages get received. data being written on server seems to continue as normal.
Implimentation is as close to stock STM multi Client example as you can get.
I actually deployed the RT Server and get the same results as running it 'interactive or debut'
another group hear ran into the same issue and solved it byt clustering everthing into one big cluster which to me is not a good solution.
08-28-2015 03:04 PM
Failed to be specific in what loop gets slowed down. the server loop that receives messages is the one that slows down.
09-01-2015 02:30 PM
