NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
Christian_L
J1939 Transport Protocol
Please post your comments, questions, and feedback on the J1939 Transport Protocol Reference Example in this thread.
Christian Loew, CLA
Principal Systems Engineer, Embedded Systems
Please tip your answer providers with kudos.
Member
hyl175
回复: J1939 Transport Protocol
hi,
maybe there is a bug in the vi named Convert CAN Arb ID to J1939 ID.vi
its path in the package is……CAN_Message_Online\J1939 Multi Packet Frame\Code\J1939 Utilities\_SubVIs\Convert CAN Arb ID to J1939 ID.vi
when the PF is smaller than 240(10), the PS in the PGN should be 0.
Member
hyl175
hi,
Member
bfeddeck
Re: J1939 Transport Protocol
Can I get these examples in version 8.5?
Member
brent2004
It would be nice if NI had a J1939 driver or add-on that would work with both the frame API and/or the channel API.  The only examples provided for J1939 here are based on the frame API, which precludes you from using the channel API with a CAN database on the same port.  The channel API is a very time saving feature for most applications.
DMC recently developed a set of J1939 protocol drivers for LabVIEW which are based on the NI-CAN channel API.  The drivers are written in LabVIEW just like the example, but provide functions at a layer above the base CAN channel API layer.  This allows the simultaneous capture of data from both J1939 packets which are simple broadcast CAN frames, or more complex transport using BAM, including extended data frames.
Although it would be nice to have an option like the Automotive Diagnostic toolkit, which worked withouot forcing a user to pick an API and stick with it for J1939 and whatever else they have going on with that CAN port.
Member
brent2004
Correct link for J1939 protocol drivers for LabVIEW which are based on the NI-CAN channel API. :smileyhappy:
Member
Julianne_K
Customers have recently requested that a J1939 Reference Example be provided for the new sbRIO-9606, which uses the RIO Embedded CAN driver.
Julianne K
Applications Engineer
Member
Djalex86
Hello , i am using the NI 9853 to communicate with a charger that use J1939.
With the project J1939 cRIO Example Project.lvproj when i send the message appears  the message code -63001-Invoke Method: FIFO.Write in J1939 cRIO Example.vi .
How can i solve this error??
Thank you
Member
Djalex86
Hello , i have this error -63001 .
How can i solve this??
Thank you
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
