NI Home
Cart Cart | Help
You are here:
Reply
Member
Danish666
Accepted Solution
sensor on sbrio
I am working on Dani 1.1 robot with sbRIO. How do i add/connect another sensor to it and test it. Its an ultrasonic sensor (maxsonar LV-EZ1).
Please help.
Member
Tori.M
Re: sensor on sbrio
[ Edited ]
Hi Danish666,
What kind of bus does the the ultrasonic sensor work by?
Using the sbRIO, there are options of communication via protocols such as wireless. If the sensor uses TCP/IP or UDP to transmit and receive data, then it should be possible to write a driver in LabVIEW RT to talk to the sensor. How complex and involved that driver may need to be will depend on the sensor.
As the sbRIO runs on real-time, we also would need to check compatability between the sbRIO and any sensor that you're wishing to plug into it as drivers may have only been developed for a windows OS. If it is compatible, then we can explore options such as communicating to it via VISA commands.
I look forward to hearing your responses.
Kind regards,
Tori M.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
