02-29-2012 05:34 AM
I know it's possible to synchronize a cRIO controller with SNTP server (condition : OS running on cRIO is VxWorks) :
http://digital.ni.com/public.nsf/allkb/F2B057C72B5
Is it possible to do the same thing with sbRIO ? (for VxWorks it's OK, it's running on it)
Thank you for any answer,
J.
03-02-2012 09:32 AM
HI Krsone,
Yes it is possible as with a cRIO.
Refer to this document (part : Using the System Clock to Provide Data Timestamp)
Rémi D.
National Instruments France
03-06-2012 02:24 AM
Thank you for your answer. I'm sorry, I should have been more precise : I'm using sbRIO-9631 and there's nothing in the specifications about SNTP synchronization.
03-06-2012 03:06 AM
Oups, I'm not using 9631 any more, I'm using sbRIO 9612 : so is it possible to perform SNTP synchronization with this platform ?
05-16-2012 01:24 PM - edited 05-16-2012 01:24 PM
Yes, the same can be done for the sbRIO-9612. You will just follow the same instruction set as VxWorks based CompactRIO controllers.
My Profile | Privacy |
Legal |
Contact NI
E-Mail this Page
