NI Home
Cart Cart | Help
You are here:
Reply
Active Participant
Julien_2831
Accepted Solution
sbrio sntp server
I know it's possible to synchronize a cRIO controller with SNTP server (condition : OS running on cRIO is VxWorks) :
http://digital.ni.com/public.nsf/allkb/F2B057C72B537EA2862572D100646D43?OpenDocument
Is it possible to do the same thing with sbRIO ? (for VxWorks it's OK, it's running on it)
Thank you for any answer,
J.
Active Participant
Remi.D
Re : sbrio sntp server
HI Krsone,
Yes it is possible as with a cRIO.
Refer to  this document (part : Using the System Clock to Provide Data Timestamp)
Rémi D.
National Instruments France
>> Les rencontres techniques de NI - Mesures et acquisition de données : de la théorie à la mise en ...
Active Participant
Julien_2831
Thank you for your answer. I'm sorry, I should have been more precise : I'm using sbRIO-9631 and there's nothing in the specifications about SNTP synchronization.
Active Participant
Julien_2831
Oups, I'm not using 9631 any more, I'm using sbRIO 9612 : so is it possible to perform SNTP synchronization with this platform ?
Active Participant
Carlton_H
[ Edited ]
Yes, the same can be done for the sbRIO-9612. You will just follow the same instruction set as VxWorks based CompactRIO controllers.
Carlton
Product Manager
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
