no functions in palette
I have a compactRIO 9074 and I want to run a vi on the hardware.
The problem I have is quite simple: the functions palette is empty on the vi created under the cRIO-9074 (see attached screenshot).
I tried to solve the problem with the procedure suggested here: http://digital.ni.com/public.nsf/allkb/46E1672AB48C917D86256AFE00075436#Palette Blank
The path in the tools options in fact points to "C:\Users\M\AppData\Local\Temp", but if i change it and restart Labview it goes back to that directory...
I'm using a freshly downloaded trial version of Labview 2014 on a windows 8 PC.
(4,546 Views)
did you install also LabVIEW RealTime module?
I cannot read what is written next to the cRIO target in the project, in case the message is related.
Bye,
Licia
(4,522 Views)
Accepted by Strech
I did!
In the end i uninstalled and reinstalled everything and it worked...
(4,520 Views)
Glad you were able to solve!
Bye!
Licia
(4,516 Views)
