07-28-2015 05:07 PM - edited 07-28-2015 05:09 PM
Is it possible for me to log data on the host computer opposed to on the controller itself? I'm needing to log quite a bit of data and I'm not wanting to use my storage on the cRIO. I'm using scan mode on the controller.
Solved! Go to Solution.
07-29-2015 12:16 AM
Lots of ways to do this. You can write a datalogger to run on the PC, to read shared variables hosted on controller and write them to a file. There is also the DSC module for logging hundreds to thousands of shared variables to a database, if you need that.
07-29-2015 06:23 AM
I recommend NOT going with the Network Published Shared Variables. They are slow and lossy. What I recommend is using a Network Stream to send your formatted data to your host PC which can just send the stream data straight to a file.
