NI Home
Cart Cart | Help
You are here:
Reply
Member
mohsen_sefati
how to implement the Transfer Function in Real Time VIs?
Hi all,
I'm relatively new to Labview Real Time modoule and want to implement one Controller(not PID one) in Deterministic Loop! I have already designed discrete Transfer Function and searching for the way to build one Controller with it! Is it right to use the Simulation Loop instead of Timed Loop (in this case Deterministic loop) and implement the controller in it?! If it's correct so, should I use the same clock and Priod as Timed Loop?!
It would be very helpful, if there is an Example about using transfer function in Real Time Loops!
thanks for your help,
Mohsen
Active Participant
PeterFoerster
Re: how to implement the Transfer Function in Real Time VIs?
to be honest: So far I haven't quite understood, what you're trying to do. Could you please be more specific.
You mentioned, that you implement ONE controller. Does this mean you have more than one controller?
Could you please be more specific on what you are trying to do? Maybe give us some sample code?
Best regards
Peter Förster
Application Engineer
NI Germany
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
