04-22-2015 12:25 PM
I get error "-2147220623" when running the following code on a cRIO 9067. It works on the cRIO 9074
04-23-2015 04:01 PM
Specifies the size of the largest block of available memory in KB on a system running VxWorks or PharLap. |
04-24-2015 11:08 AM
Right, that property does not apply to Linux targets, as noted in the error description:
Error -2147220623 occurred at an unidentified location
Possible reason(s):
NI System Configuration: (Hex 0x80040371) The property does not exist for this resource.
04-29-2015 01:22 PM - edited 04-29-2015 01:22 PM
Ok, thank you for clarifying! I know that monitoring the largest memory block and avoiding memory fragmentation is emphasized in the cRIO/ LabVIEW RealTime courses. So for Linux RT targets, we should just look at total memory available?
04-30-2015 11:29 AM
Monitoring the free physical memory (provided in KB) is a recommended method for checking memory availability on Linux RT targets.
