displacement sensor without using fpga
hello,
im new here and i´d like to know which sensors i can use to measure displacement without the need to use FPGA or LVDT 9312
thanks
(4,776 Views)
Hello zylaar7
If you don't want to use the LVDT 9312 module, you can always try to aquire the signal, aconditionate it and process it in LabVIEW using a Data Adquisition Device. However, remember that you will need to decode all the signals by yourself. The LVDT 9312 module decode the signals without any aditional signal adaptation.
Here's a white paper in how to make an encoder measurement.
http://www.ni.com/white-paper/7109/en/
Maybe it will help you. Cheers.
Omar R.
Technical Support Manager
CLA | CTD
(4,752 Views)
