compactrio and 9237 getting started
I'm new in Labview. I have a Compactrio 9076, connected with a module 9237 and a Load Cell. I already connected everything with success ( NI 9237 Getting Started.vi is connected and working without problem), but when I try to compile the example: NI 9237 Getting Started (Host).vi some wires show error. I attached the image.
How can I solved it, in order to compile the example (Host)?
Thanks in advance.
(3,357 Views)
Accepted by topic author DinC
You need to configure the Open FPGA Reference to point to the bitfile you generated for the FPGA.
GCentral
(3,353 Views)
is your problem solved????
(2,406 Views)
