02-02-2015 03:25 PM
I have a cRIO 9067 and would like to interface to an instrument that has a SiLabs USB-RS232 converter. I can comminicate with this instrument easily on a Windows PC. I am able to see the device in MAX when its connection the cRIO. IT shows up under "Devices and Interfaces" as "USB0::0x1FB9::0x0100::121A00A::RAW" with the Model number and the device description.
I've followed the description at this link, but I don't get a ttyUSB# devices.
https://decibel.ni.com/content/docs/DOC-34827
Is there any chance to get this working on the cRIO as a serial port?
Thanks.
Solved! Go to Solution.
02-03-2015 04:28 PM
Hello immercd1,
Try following the steps followed in the second post here:
Let me know if that works for you.
Thanks!
02-05-2015 11:49 AM
I don't have that file /etc/mdev.conf.
Is it possibly in a different location on the 9067?
02-05-2015 01:00 PM
I created the file at /etc/mdev.conf with the line:
ttyUSB[0-9]* root:tty 666
restarted the cRIO, but the device still shows up as a usb raw device.
02-06-2015 12:02 PM - last edited on 01-11-2024 05:18 PM by migration-bot
Hello immercd1,
Lots of changes were made in the file structure when the 9067 was released. This document helps outline how to connect to USB devices with the new structure:
Let me know if you have any other questions!
03-13-2015 01:57 PM
After some digging, talking with NI Folks, google, and Talking with Folks at lakeshore.com (device vendor) here's what I've piece together on how to get this to work:
#typical devices
KERNEL=="ttyUSB[0-9]*", OWNER="admin", MODE="0666"
