11-19-2015 10:05 AM
Hello Dargm,
Sorry for the delay in my response. Can please all the necessary files (VI and Library) in order to run some tests. I also saw that the error message makes reference to the call library function node. What dll is being called?
11-19-2015 10:37 AM
Hi Dargm,
I see. Please excuse me for asking some further basic questions, though I'm pretty sure you thought of these:
* It almost seems like you don't have the WebDAV Client 'driver' installed on your target. (Use NI MAX to add/remove software/drivers from your target.) Did you install the WebDAV CLIENT driver for your RT target? If not, you'll get various errors when running on the target.. I haven't tried it explicitly on my test setup (time-constraint) but it seems plausible that you may get a 'file/folder missing' type error if the library isn't deployed/installed. You need to add it from MAX (or maybe the NI-RT Linux targets has it installed by default).
Since you error out on the 'open' session VI, I think the item above is the most promising.. Once you get past that (open session) without error, you may also consider the below:
* Did you manually create a local root folder on your RT device called 'data'? Please remember that on Linux targets, file and path names are CaSe Sensitive(!). Depending on your target OS, / vs \ also matters. The example I put up was targeted to 9014, a vxWorks target.
Keep me posted, I'll keep an eye on this to see if I can assist further.
11-19-2015 01:47 PM
Hi QFang,
You are correct, my issue turned out to be the WebDav Client not installed on my cRio, I did not realize that the WebDav interface has two componets, a Server and a Client. I just installed the Client on my cRio and the example works fine.
Thanks for your Input.
