06-18-2015 10:22 AM
What resistor values are you using? Try using a different pair of resistor values. I tried different pairs before settling on 100 Kohm.
06-18-2015 10:27 AM
Forgot to mention that the resistor values should be between 10 kohm and 100 kohm, as written in the paper I posted earlier.
06-19-2015 02:24 AM
Thanks for the reply
I tried using 100 kohms and 50 kohms, any way the problem is still there.
06-19-2015 09:46 AM
How about using only one resistor for each of your thermocouples? Join the negative end of the thermocouple wire to a resistor joined to ground and see what happens. Again, try different resistor values.
