Starting a sub vi dynamically with the start asynchronous call. Not closing
My goal with this program is to cycle various digital outputs according to a user set time.  I am launching a sub vi dynamically to accomplish this.  The main event based program works as I would like it to.  The problem is in the sub vi.  When it receives the boolean true it works as it should.  When I send a boolean false it goes through the first case structure with the false value but then the value changes back to true.  After starting a timed loop on a digital output channel as I would like, I am not able to stop this loop when I change the front panel boolean for this digital output channel.  I believe the problem has something to do with the "Prepare to call and forget" way that I lauch the cycle.vi. The first instance never closes when I call the second instance.
I use "DO Main Program.vi" to take events from the front panel, and then "Cycle.vi" to cycle the channel on a user defined time.
(4,742 Views)
Hey Brad,
Have you seen these documents? They should give you some clarity on the Asynchronous calling methods and options.
Asynchronously Calling Multiple Instances of a VI for Parallel Execution
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/acbr_call_clones/
Combining Option Flags into a Single Option Value
http://zone.ni.com/reference/en-XX/help/371361J-01/lvhowto/combining_options/
Douglas Choisnet
(4,716 Views)
Thank you, this is helpful.
(4,711 Views)
