Spikes in data when FIFO buffer is reduced
The Sample Clock is a clock exported by the CLIP and you'll need to place the AI node inside of a SCTL that uses that clock. However, the Sample Clock is only available in the most recent version of the NI FlexRIO driver.
If you are using an older version of the driver then you will need to use the IOModClock to drive the SCTL that the AI node resides in. See the image I attached in my last post to see which version requires which clock. If you are using an older version, then I recommend going through the 5733 user guide for information on how to setup the IOModClock.
Message 11 of 14
(2,235 Views)
David-A,
Thanks for the help. Everything is working properly now.
Message 12 of 14
(2,221 Views)
David,
As I said previously everything seems to work fine. However, it looks like I cannot have as much logical operations as I had in the SCTL when I was using the 40 Mhz Onboard clock. For example, when I was using the onboard clock I was able to have 3 addition, 3 multiplication operators along with 3 DMO FIFO objects, but when I changed the clock to IOModClock (40 Mhz), all I can have in the loop are 3 multiplication and 2 addition operators. Inserting additonal objects lead to timing violation. Is this expected? If so, what is the difference between the onboard clock and the IOModClock? Thanks for you time.
P. S. I am pipelining to optimize the fpga VI
Message 13 of 14
(2,194 Views)
Can you start a new thread? The issue you are seeing is unrelated to the OP.
Message 14 of 14
(2,190 Views)
