05-15-2015 06:08 AM
I'm starting with Labview RT.
I would like tor read out a thermocouple signal, sending it afterwards to the Host VI. It works but far to slow.
I've tried to look at CPU, Memory Usage but there comes my second problem. The DSM does'nt contain the functions it should.
Am I missing a special configuration?
05-15-2015 06:54 AM
Network Published Shared Variables are slow, especially in a high traffic network. I would recommend using a Network Stream and set up your own communications scheme that can handle the higher output rate.
05-15-2015 08:46 AM - edited 05-15-2015 08:54 AM
Thanks for the fast answer. A wait function works as well for those who are not interested in a high resolution.
I've opend a new thread referring to the dsm question.(http://forums.ni.com/t5/Real-Time-Measurement-and/dsm/td-p/3135168)
