Sbrio-9636-9636
Hi
sbrio 9636-9637 supply voltaj 24 volt  how much requiret current?
(3,761 Views)
Osman87,
The current necessary is very dependent on the power use and requirements of your application and based on what lines you are using.  You can find out more about that here (http://www.ni.com/pdf/manuals/373378c.pdf) in the manual under the power requirements section.
Aaron L.
(3,747 Views)
