01-18-2016 03:55 AM
01-19-2016 09:16 AM
Hey Cairo,
Make sure to be thorough. It's easy to miss a step or overlook something small.
http://digital.ni.com/public.nsf/allkb/ABE4BC247E8AC9BC8625734E005CAB42
You can use the Knowledge Base to do a thorough walk through of everything and setting all settings.
Let us know how it goes.
Cheers,
Bear
01-25-2016 06:25 PM
01-26-2016 09:15 AM
It works, but I have to do it for every time I connect to my laptop.is that normal ?
Do you mean that you have to refresh MAX everytime or that you have to format disk, put DIP switch On, restart board, DIP switch off and then refresh MAX to see it your sbRIO?
But after compilation at the Sb Rio it compiled successfully, but no output, it give zero at the waveform graph
What was the waveform graph putting out before? You'd have to debug your code to be able to ask a more specific question.
01-26-2016 10:55 AM
Dear engineer at first i want to thank you for your help, i realy appreciate your efforts .
again i want to let you know i think my problem solved using the link you gave to me, when i installed the system configuration.
but the problem that i have to do all those steps ( put DIP IP resrt switch to on, then restart the board Push button, then put the DIP IP resrt switch to of then refresh MAX ) every time, is that normal ?
about my program problem : attached to you my FFT program which work very good at simulation but not working at real SbRio 9642 after succesfully compilation.
Please help me as much as you can.
Eng M Samy
01-26-2016 12:44 PM
Is there a reason in your "Target.vi" you are working with an Analog Input (AI1) and not an Analog Output?
01-26-2016 02:23 PM
01-27-2016 11:37 AM
Can you see a signal coming out of the module?
Also, what do you mean running in SIMULATION mode worked fine on the sbRIO?
Bear
02-01-2016 09:52 AM
Have you worked on the issue at all?
How is it going?
-Bear
