Replication Ane Deployment : module configuration
Hi all,
I've got a cRIO system  (RT + FPGA) using a 9203 module.
In the FPGA, the module can provide calibrated or raw data. You can choose one mode or the other right-clicking the module on the LV project and choose properties.
In my case, I chose to work wit raw data !
My code works fine (RT (exe) + FPGA) , and I used the RAD tool to duplicate my code onto another cRIO (same ref, same module). Everything works fine on the new cRIO, except the 9203 module which is seen as Calibrated !
Why does this option hasn't been set with image deployement ?
How to set without using LabVIEW ? (I don't want to open a LV project, add a new target, set my module, etc... for every cRIO I'll need to 'flash')
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
Message 1 of 1
(4,843 Views)
