08-14-2014 12:43 AM - edited 08-14-2014 12:45 AM
I cannot get ftp to work with a cRIO-9012 Controller. It used to work with LabVIEW 8.6.1, but our IT department has forced us onto Windows 7, so I'm forced to use a newer LabVIEW.
I can get access, but cannot do directory listings or transfer files. What I can and can't do can be seen in the Command Prompt screenshot below:
I can ftp in, I can log in, I can change directories. However, the ls command results in everything hanging. I need to ^C to regain control.
I can open files in Internet Explorer or Windows Explorer, but not using Command Prompt commands. I need to get the Command Prompt method to work so that I can use the System Exec.vi to automate the process.
I'm using Windows 7 Enterprise, NI CompactRIO 14.0.1 - August 2014.
08-14-2014 01:41 AM
Thanks to my work colleague Peter, this is now solved. As probably expected, it was a permissions issue. The website http://superuser.com/questions/215775/command-line-ftp-function-does-not-work has the solution, which is shown below.
I had an issue with transmitting files via FTP once I was logged into the box in question. It would create the file name, but the file was empty. I resolved by doing the following:
Vito
