04-11-2013 04:05 PM
I want to replace my PCI 7833R FPGA card with a newer and better FPGA and with PCIe bus if possible. I want to make as little change to the LabVIEW code as possible, but I notice the potential changes that I have to make so far. Are there ways to get around them? Are there more changes that I should anticipate?
1. device change. I assume I can change that pretty easily in the project explorer. Any pitfall?
2. The PCI 7833R uses integer to represent floating point for its analog I/O. Other new devices use fixed point or floating point directly, which mean I have to make a lot of code change. Can I make the new device to uses integer for analog values?
04-12-2013 09:44 AM
jyang,
Our cRIO and sbRIO products use the fixed-point data type for analog input, however all R-Series PCI & PCIe devices still use raw integer data to represent analog input.
Your code changes should be very minimal if any. You'll have to add a new target to your project and add FPGA I/O, but if you give the channels the same aliases as they had on your previous target you'll just have to drop the FPGA VI & other project items (memory, FIFO, etc) under the new FPGA target and all should be well.
Remember that you can try this and compile for a different FPGA target before you even purchase the hardware. Since you can get your resource utilization and timing reports, this might be helpful in deciding which R-Series board you'd like to go with. Take a look at the KnowledgeBase titled "How Many Slices Does My FPGA Chip Have", this will give you a rough estimate of how much larger the other FPGAs are, but it doesn't include specialty resources like DSPs, BRAM, etc.
Hope this helps!
04-12-2013 10:10 AM
Are you using the 7833R with Labview 8.5.1 or older? The PCIe board is not supported until Labview 8.6. There is a chart some where showing minimum software versions but I cant seem to find the link.
04-12-2013 04:06 PM
Using 2011
