NI c-RIO 9035 - problem with software instalation on the device
Hi everyone,
I'm a beginner in labview RT. I have problem with new NI cRio-9035. I'm unable to log into device and install software on it and log in (device is in safe mode).
I tried instal software on cRio both by LAN and USB cable. When I try axpand my NI cRio in Remote Systems in NI MAX i can't see Software (and the same I am unable to install it on cRio module).
IP adress was properly assigned. There are no problems using Troubleshoot Remote System Discovery tool (all ok).
 When connected via ethernet: sometimes device is not visible in MAX but cRio is all the time connected to LAN.
I have no idea what's the problem.
I will be grateful for any suggestion.
(2,806 Views)
Hi mlbos
Is there a reason why you use a static IP address?
The first time I had to setup a CompactRIO I used this file: http://www.ni.com/getting-started/set-up-hardware/compactrio/first-use. This will help you to get through the first installation.
Regards
Jasper
(2,774 Views)
Hey mlbos,
What is the message you see when you try to log into the cRIO?
If you're on a laptop, I recommend disabling the wireless network NIC. Sometimes having multiple active NICs can cause problems with MAX.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(2,752 Views)
I did everything written in the manual. Always wireless network was disabled (when connecting by USB). But i solved this problem: I installed the updates even though I had all the necessary programs installed. It helped.
Thanks for the commitment.
(2,748 Views)
