07-14-2012 08:40 AM
Hi
When i open the Distributed System Managerand and i Eexpand my CompactRIO system in the left-hand column
i dont see my I/O module (NI 9870) listed below my CompactRIO system.
Can you tell me why?
regards
07-16-2012 07:18 AM
07-18-2012 08:40 AM
Hi Wayne.C
In the MAX , underneath my cRIO softwares i see "NI serial RT 3.6.0" .
is it other softwares to install for NI 9870 ?
regards
07-18-2012 08:45 AM
That will depend on whether you are running the 9870 in FPGA or scan mode. What version of LV are you running?
07-18-2012 09:07 AM
I want to use the NI 9870 with LV FPGA..
i have LV 2010
and this is my MAX:
07-18-2012 09:16 AM
Since you are going to run in FPGA mode, you won't need to add the scan support for the 9870. Looks like you have everything that you need loaded on the RT target.
07-18-2012 09:26 AM
Thx
Can you give some link to help me how to use NI 9870 with LV FPGA
I want to send command to my periphiral then read what i recieve
07-19-2012 07:17 AM
There is a very good example that ships with LV. Just do a search on 9870 in the examples.
07-25-2012 09:26 AM
Hi Wayne.C
I have already moved the exemple to my project CompactRIO, but when i want to run a VI for example the " 900x 9870 DMA Config (Sub).vi "
I find these errors
Can u explain why these errors and how correct them
07-25-2012 10:28 AM
moonm,
Can you post an image (.png) of your Project Explorer window so I can see how you have your project set up?
My Profile | Privacy |
Legal |
Contact NI
© 2011 National Instruments Corporation. All rights reserved. | E-Mail this Page
E-Mail this Page
